How To Fix The Access To Google Docs Denied Issue?
I get access to google docs denied message when I try to access Google docs. The same thing happens with Google drive. I cannot understand the reason behind this. Is there any solution to this?
The first trick to fix the access to google docs denied error is to log out of any Google account on your PC and sign in with the account you want to use for Google drive.
Method 1
a. Open Google.
b. On the top right corner, click on your user icon.
c. Sign out from all the accounts.
d. Sign in with the one account you want to use.
e. Google drive/ docs should work.
Method 2
a. Use Google Chrome in incognito mode.
b. Open Google Chrome.
c. Click on the Google menu icon.
d. Choose the Incognito mode.
e. Try to access Google drive/ docs.
Method 3
If you have installed an extension recently, you should try to disable that.
a. Open Chrome.
b. Type chrome://extensions in URL.
c. Press enter.
d. Delete all the unnecessary extensions.
e. Restart Chrome.
f. Try to access Google Drive/ docs.
