I installed the office in my system and run windows update. When I tried to use the office after the update I got the software change error code 0x80070663 I have uninstalled the apps and reinstalled them again. There is no problem for some time, but the installation failed after some days. What can I do know?
How To Fix The Windows Update Error Code 0x80070663?
It usually happens when the windows installation is done improperly or corrupted. Most of the cases it is seen during the installation of office. It can also solve by upgrading to the new version. It sometimes may also occur due to the down of the server.
It also due to the deletion of the file from the windows installer cache. Sometimes it may be solved just by restarting the system or reinstalling the app. You can run windows troubleshoot. Then restart windows update components and install all the updates in windows that are pending. Try to reinstall the office once again.
