How To Fix Windows 10 Update Error – 0x8007001f-0x200006?
Hi, I am unable to update my Windows 10 version. I have already tried the Windows update troubleshooter, but it does not help. I get a 0x8007001f-0x200006 error code. How can I fix this?
Try the below methods to fix the 0x8007001f 0x200006 error in Windows 10.
Method 1
a. Open Command Prompt as Administrator.
b. Type net stop wuauserv and press enter.
c. Type net stop cryptSvc and press enter.
d. Type net stop bits and press enter.
e. Type net stop msiserver and press enter.
f. Type Ren C:\Windows\SoftwareDistribution SoftwareDistribution.old and press enter.
g. Type Ren C:\Windows\System32\catroot2 Catroot2.old and press enter.
h. Type net start wuauserv and press enter.
i. Type net start cryptSvc and press enter.
j. Type net start bits and press enter.
k. Type net start msiserver and press enter.
l. Restart your device, and update your Windows.
Method 2
a. Open This PC.
b. Go to the Windows folder.
c. Click on the view option in the menu bar.
d. Select Show hidden files and folders.
e. Delete the two folders shown in the picture.
f. Try to update the windows now.
