How To Fix Windows Setup Error 0xC1900101 – 0x40017?
I tried to upgrade from Windows 8.1 to Windows 10, but my screen is stuck at a particular Window stating error 0xC1900101 – 0x40017. How can I upgrade to Windows 10?
You can try the following methods to solve 0xC1900101 – 0x40017 errors.
Method 1-
a. Press Windows + I using keyboard.
b. Search Firewall.
c. Open Windows Defender Firewall.
d. Click on Turn Windows Defender Firewall on or off.
e. Turn off Windows Firewall for both public and private networks.
f. Click OK.
g. Restart your device.
h. Try to run the upgrade.
Method 2-
If you are using third-party antivirus, disable it and try to run the update.
a. Search for your antivirus in the taskbar’s search box.
b. Open it.
c. You will find a Turn off firewall button.
Method 3-
Make sure you have enough space in your hard disk where you are installing Windows 10. You need at least 16 GB space in your device.
