How To Fix Windowsupdate_c1900101 4000d
I’ve been trying to fix this windowsupdate_c1900101 4000d error but was never successful. Can anyone help me solve this problem?
Follow the instructions below and check if it works for you or not:
• Unplug all the external devices like USBs and internet connections.
• Disable the anti-virus and allow the public access to windows update using windows firewall.
• Do the System File checker scan:
– Open CMD as administrator
– Type:
Scf/scannow
This will check all the corrupted file and will replace it with legit ones.
• Now restart your PC. Check for updates
• Or else go for safe mode before searching for updates.
• Other than this you can try a manual update.
