Q1 – Hi, can someone help me to fix Xbox backup creator error 339?  I have tried many things rather than re-installed my Windows also after searching over the internet, but nothing seems to work. Can anyone help me out?
Q2 – I am using 64-bit windows. Please help me!
How to fix Xbox backup creator error 339?
A1– Hey, do not worry, I have an easy fix for that. Please tell me whether you are using 64-bit Windows or 32-bit Windows.
A2 – You need to install a component named – MSCOMCTL.OCX. Here is the link to it – https://www.microsoft.com/en-us/download/details.aspx?id=10019. Always go to Microsoft site for installing such files. After downloading the file, extract it. Copy MSCOMCTL.OCX file and paste it in the folder where Windows is installed. Find this path – C drive -> Windows -> SysWow64.
Now open the command prompt and follow the steps below –
1 – Type cd/ and hit enter.
2 – Type cd c:\windows\syswow64 and hit enter.
3 – Type regsvr32 mscomctl.ocx and hit enter.
4 – Restart your PC.
This will solve your problem.
