How To Fix Zlib1 Dll Missing Error
When I try to unzip any file, I start getting the zlib1 dll missing error. I tried to restart the computer but this did not help. Is it possible for me to fix this on my own or do I need to call tech support?
You can solve this error on your own so there is no need to call tech support. Most of the dll file missing errors can be solved easily. These are also very common errors. So, if you get this error again for some other dll file, you can follow the same steps.
What you need to do is download the missing dll file from the internet. Then place the dll file in the required folder. Please be advised that downloading anything from the internet poses risk to your system. Only download stuff from the internet from websites that you trust to avoid getting infected with viruses or malware.
