Hello, friends, I am facing task sequence error, and at some steps, I am getting different task sequence error codes on my laptop. What should I do to get the solutions and how can I see the error code problem?
How To Fixtask Sequence Error Codes Troubleshooting In SCCM.
Hey, there are several task sequence error codes which are fixed in some steps. For the error to be identified whenever your SCCM task sequence fails you should go to the smsts.log file where you can see your error code and based on that try to find out the solutions. Some of the errors are 0x80070032 which is solved by formatting the diskpart.exe,0x80073ee7 is fixed by changing the port of the Ethernet cable,0x80070241 is removed by restarting with boot CD or PXE etc. Similarly, you can search for more once you get the know the error.
