How To Get Rid Of 0x8007045a Error?
My Windows 10 PC is not working properly. I do not understand the problem. I encounter a 0x8007045a error, I need to restart my PC every time, and this is annoying. Please help me.
0x8007045a error occurs due to mismatch system files. Fortunately, the fixes are very easy.
Method 1
a. Go here
b. Download the XML parser.
c. Run it.
d. Your error might be gone. If not, go to Method 2.
Method 2
a. From a working computer with the same Windows version, take three files – Msxml3.dll, Msxml3a.dll, Msxml3r.dll
b. Location of these files – C drive-> Windows folder-> System Folder.
c. Press Windows + R key.
d. Type REGSVR32 C:\WINDOWS\SYSTEM\MSXML.DLL and press enter.
e. Type C:\WINDOWS\SYSTEM\MSXML2.DLL and press enter.
f. Type C:\WINDOWS\SYSTEM\MSXML3.DLL and press enter.
g. Restart your device.
