How To Get Rid Of 0x800706be Audio Error In Windows 10?
Audio on my computer is not working. I am getting a 0x800706be audio error. How can I get rid of the problem? Thank you in advance.
You can try the following methods to solve the 0x800706be audio error.
Method 1
a) Press Windows + R key.
b) Type services.msc, and press enter.
c) Find the following services – Windows Audio, Windows Audio Endpoint Builder, Remote Procedure Call (RPC)
d) Right-click on each of the services, and click on Restart.
Method 2
a) Right-click on the start menu.
b) Open Device Manager.
c) Expand Sound, video, and game controllers.
d) Right-click on your audio driver.
e) Uninstall device.
f) Check the option, Delete the driver software for this device.
g) Click on Uninstall.
h) Restart your computer.
