I have an active internet connection, and I can use internet-based apps except for the Microsoft Store in Windows 10. I get a 0x8007ee7 error that says the network has stumbled. I have updated Windows and used LAN cable directly, but it did not solve the problem. How to get rid of 0x8007ee7 Microsoft Store error?
How To Get Rid Of 0x8007ee7 Microsoft Store Error?
You can fix the 0x8007ee7 Microsoft Store error by registering the Microsoft Store package or making changes in the Network.
Method 1
a. Open Command Prompt as Admin.
b. Type PowerShell -ExecutionPolicy Unrestricted -Command “& {$manifest = (Get-AppxPackage Microsoft.WindowsStore).InstallLocation + ‘\AppxManifest.xml’ ; Add-AppxPackage -DisableDevelopmentMode -Register $manifest}” and press enter.
c. Restart your device after the process completes.
d. Open the MS Store.
Method 2
a. Press Windows + R.
b. Type ncpa.cpl and press enter.
c. Right-click on the network that you are using.
d. Go to Properties.
e. Double click on the option shown in the image.
f. Click on “Use the following DNS server address.”
g. Set the address as shown in the image.
h. Save the changes.
i. You will be able to use the store now.
