I have purchased a new Dell Inspiron laptop, and it was working till yesterday, but today when I started the laptop, it reached till the desktop and then the bluescreen appeared with message pool_corruption_in_file_area. What to do now?
How To Get Rid Of Pool_corruption_in_file_area Blue Screen
If you are getting a blue screen, this generally means that something is seriously wrong with your computer. The message you are getting pool_corruption_in_file_area
Means that a corrupt driver has created problems in the pool area where the pages reside.
This error usually occurs after the installation of a new program. This happens due to the installation of a malicious program or an incomplete installation. To remove this error, run a complete scan of your system to make sure that you are not infected with any virus. If you are not a power user, I would suggest calling tech support.
