How To Get Rid Of The 0xc0000000e Error In Windows 10?
When I am booting in my Windows 10 PC, I am getting a blue screen with error code – 0xc0000000e. How can I solve it?
The 0xc0000000e error is fatal, but you can get rid of it. The steps are lengthy; please follow carefully.
a. Insert the bootable media (installation media of Windows 10), and boot from there.
b. Select language, time, and keyboard, and click on Next.
c. Click on Repair your Computer.
d. Click on Troubleshoot.
e. Click on Advanced Options.
f. Open Command Prompt.
g. Type bootrec /rebuildbcd, and press enter.
h. Press Y after installation media is found.
i. Wait for the process to complete.
j. Type bootrec /fixmbr, and press enter.
k. Type bootrec /fixboot, and press enter.
l. Reboot into your PC after the process completes.
Method 2
e. Go to Advanced Options.
g. Type diskpart and press enter.
h. Type list disk and press enter.
i. Note the number of the disk containing the Windows OS.
j. Type Select disk # (replace # with your number), and press enter.
k. Type Online disk and press enter.
l. Type Exit and press enter.
k. Boot into Windows now.
