Zorian mat
5 points
Posted on - 06/08/2020
Hey, experts I am facing some issues with my windows latest version, I want to contact the technical team, and I want to seek their assistance.
Please help me, How to get technical support for windows issue?
How to get technical support for Windows?
Hello, as windows is a Microsoft product, you can get technical support for windows, by contacting Microsoft Support Team. Microsoft provides various types of support options to its product users.
Microsoft provides technical support options by considering the customer’s location and assigns the appropriate support team to solve technical issues faced by customers. This service includes self-help support and assisted support. Just clik here, select your country, and go to the menu bar, select the product for which you want to seek support. Moreover, if you wish to message a Windows advisor visit this link.
If your windows is latest version, i.e., Windows 10, you can use the contact support app. You can also contact using this phone number 8006427676 or by visiting Microsoft.com/contactus. Thank you,
