Bersh Roman
30 points
Posted on - 06/15/2020
I bought Acrobat 11 pro from adobe.com. As I was trying to install the software on my laptop, the software asked for the serial number. I forgot to note down the Acrobat 11 pro serial number when I bought it. Is there any way to get the serial key?
How To Get The Acrobat 11 Pro Serial Number?
You can use either of the two methods to get your Acrobat 11 pro serial number:
1) Go here and log in using your email id and password. In the top right corner of the page, to the right of the search bar, you can see the ‘account’ option. Click on it; a drop-down list will appear, click on View Account.
A new page will open. Click on ‘View plan.’ In the ‘Plans’ page, click on ‘Order history’ on the left side of the web page. You can see your orders on this page. Click on the desired ‘ORDER#,’ and then click on ‘Downloads and Serial Numbers.’ Your serial number for the desired software will be displayed.
2) To make your work done faster, directly go to this link. Log in with your email id and password.
A new page will open. Click on ‘View plan.’ Click on ‘Order history’ on the left side of the web page. You can see your orders on this page. Click on the desired ‘ORDER#,’ and then click on ‘Downloads and Serial Numbers.’ Your serial number for the desired software will be displayed.
