Jackman
Posted on - 10/21/2017
Hello everyone,
I want to sync all my phone contacts to my Outlook account. Please provide me the procedure to Google contact sync outlook. Currently I am working in Outlook 2013.
Thanks in advance for the help.
How To Google Contact Sync Outlook 2013?
To sync your contact first you need to export your Gmail contact. Follow the steps to export.
- Open Gmail account then navigate to the contacts.
- Click on more then select export.
- Select the group you are willing to export.
- Select Outlook CSV as the format.
- Click to Export.
- Browse the location.
Next step is to import the contacts to Outlook.
Click on file, and then select open & export. Click Import/Export.
Select import from another file or program and the hit on next. In the Import a file box, navigate and search for your file and select it. Click on next and then select the destination place.
Choose next.
Now open outlook and click on address book, choose the name of your mailbox.
All the contacts will be visible now.
