I figured out that my eyesight is getting weak when I was unable to read clearly on my computer. It will take some time for my specs to arrive. Meanwhile, I want to increase the font of my computer. I use Windows 8. How to do this?
How To Increase Font Size Windows 8
Subtle settings and personalizations such as increasing the font size of the computer are pretty easy if you know where to find these settings in the first place. Most users want to make such tweaks but are unable to do so because they do not know where to find these options.
To increase the font size on Windows 8, open the start screen, click on the desktop tile. Right-click anywhere on the desktop and select personalization. On the left, you will find the Display option. Click on the Display. Here, you will find your font options. Change the settings according to whatever you want.
