How To Increase The Ram Of My Laptop
I’ve been seeing a lot of lagging issues in my PC; I think it might be the thing of having less RAM. Is there any way of increasing the RAM of my computer.
If you are talking about a desktop, then it is easier than you think it is. You can watch a tutorial to install the RAM, or you can go to a nearby service center to do so.
If it is a laptop, then you have to check if it is compatible for increasing of RAM. If it is compatible, then watch some tutorials on YouTube. If not, you may not be able to install physical RAM.
But don’t worry, there is a weird way of using a PENDRIVE to work as a temporary RAM to increase the speed of your PC. This method uses the memory of your PENDRIVE, make sure that the PENDRIVE you use doesn’t have anything in it because you have to format it to use it as a temporary RAM.
Steps to convert PENDRIVE memory to a temporary RAM:
• Plug in your PENDRIVE
• Right-click on your PENDRIVE
• Click on format
• Right-click again and go to properties
• Now click on Ready Boost
• Choose the amount of memory you want to convert and apply
Notifications
