How To Indian Standard Time To EST Conversion?
Hello everyone,
I was keen to know that how I can perform Indian standard time to EST conversion. Please provide me the best suitable sites for the conversion.
Thanks in advance for the help.
Hello everyone,
You can go to https://www.worldtimebuddy.com/est-to-ist-converter for the exact conversion. This site is most suitable for every type of time conversion.
You can also see the time conversion for various dates.
There are other options also available on this site.
There is also mobile app of this site so that you don’t need your PC for every time you need conversion.
“IST” or “Indian Standard Time” is set at UTC +5:30 which means 5:30 hours ahead of Coordinated Universal Time or UTC. “EST” or “Eastern Standard Time” is set at UTC -5:00 which means 5 hours behind Coordinated Universal Time or UTC. These differences between the time zones are between IST and EST with UTC.
Now, with regards to the time difference between IST and EST, EST or Eastern Standard Time is 9.5 hours behind IST or Indian Standard Time. That’s why, if it is 9:30 AM IST, it will be 12:00 AM EST. If you want an easy conversion between Eastern Standard Time and Indian Standard Time, go to Converting IST to EST.
