How To Install Ca Certificate?
Hello, let me tell you how to install ca certificate for HTTPs protocol that connects to a server. To install on Microsoft Windows,
1. Open Start -> Run -> mmc.exe (Microsoft Management Console).
2. Choose File-> Add/Remove Snap-in option. Select certificate snap-in from the left-side and then click “Add” which will get added into the right side box. Now a wizard opens, choose “Computer Account” and then choose “Local Computer” then click “Finish”. Now go to Certificate(on your local computer).
3. Now you can import a CA certificate to the desired storage place on your computer, but you can do it only by two possible options.
a. If you have a CA certificate, choose “Trusted Root Certificate Authorities”.
b. If you have the certificate for the server itself, chose the “Other people” option.
4. Now right-click on it and choose Tasks -> Import. Do as per in the wizard and now you have required CA certificate install on your computer.
