Hi, I am working at a Non-profit Government organization. In my workplace, I have two systems on the 1st and 2nd floor of that building. I can access only access one system but I want to access both so that I can work efficiently. So, can somebody help me with how to install remote desktop?
How To Install Remote Desktop?
Hello, as you asked for connecting both systems within one system, it is possible by remote desktop connection on both systems. Let me explain to me the easy procedure on how to install remote desktop?
1. Open Control panel in 1st system. In the search box, type “remote access”.
2. Under System, click on “Allow remote access to your computer”.
3. Now System properties wizard open, then select “Remote tab”. In the Remote tab, select the option as “Allow remote access to your computer”. Click “Apply” then “ok”.
4. Now repeat step 3 in 2nd system also. Now either in any system, open Run (press Win+R) and type “mstsc” then click ok. Now Remote Desktop Connection wizard open, type other system’s credentials and connect both systems.
