How To Install Windows7 Home Basic 64 Bit Using CD?
Hello experts,
I have a CD which has Windows 7 home basic 64 bit. I want to install it on my PC. Please provide the steps to install it.
Hello experts,
Sure, here are the given procedures through which you can download windows 7 home basic on your system.
Step1. Create the backup (if any) of your files and folder.
Step2. Get intobios of your system so that you can boot from CD. To get into bios of your system restart your system and keep pressing f8, f2, f12 or del. If you are installing from flash drive, choose removable storage.
Step3. If youproperly inserted the CD and you have entered in BIOS, then a window will appear.
Press any key if you see this.
Step4. Your window file will start loading.
Step5. Choose your preferences.
Step6. It’s time to install Windows.
Step7. Read the terms and condition and accept if you want to and click next.
Step8. Choose custom option.
Step9. Provide the partioning and click next.
