How To Java 2 SE V1 6.0 _01 Download.
I want a link from which I can direct Java 2 SE v1 6.0 _01 download from the official site of java. Can anyone provide me a better link to download java?
If you want to install java, then you have to open the java website. Java is now a part of Oracle.
The above-posted link will land you directly on the Oracle java download page. It can resolve your issue about the downloads simultaneously.
Use the distributed link here.
If you want to download the Java Virtual Machine or Java Runtime Environment, go to Java SE Runtime Environment 8. Before you download, select “Accept License Agreement” then select your platform from the list. Java Runtime Environment is available in four operating systems: Microsoft Windows, OS X, Linux, and Solaris. For Microsoft Windows, you can download either 32-bit or 64-bit and either online or offline.
If you select the online installer, you will download a tiny executable that will initiate the actual downloading of the installer and automatically installing it afterwards.
