I’m purchasing a new edition 3D designing tool, but before purchasing, I want to check my Computer configuration detail as this product is new in the market and demand extra features and power to support. Please help me to get to know so that I can check my computer configuration.
How To Know Computer Configuration Details?
Technology is upgrading day by day to its functions and values. Also, designing tools turned as a boom for digital technology. A designing software helps in finding bugs, debugging, restructuring, and transforming the designs. All of it is done in software that makes it very economical and easy. Companies releasing their software nowadays are bulky and contains loads of function, which makes it dependent on the performance of the computer. So to check your Computer configuration details follow these steps: –
1. Click on the Start Menu.
2. Type system information. Left-click to open it.
3. Here you will see a window pops up with the name system summary. It provides you details about the operating system, processors, input/ output system, RAM installed on your personal computer.
4. On the left pane, there are more options given, if you want to know additional details like driver and hardware from the list.
