Hello experts, I recently switched to an Android phone and wanted to connect on social media. I was curious to know that what is the procedure to make a new WhatsApp account on Android phone.
How To Make A New WhatsApp Account Using An Android Phone?
Creating a WhatsApp account is very simple. You can create an account on WhatsApp just by following these steps:-
Step1
Very first step is to install WhatsApp application on the phone. Either you can download it from play store, or you can also use ShareIt or another app to get it from somebody else’s phone.
Step2
When you will successfully install WhatsApp on your phone. Touch the icon, a dialog screen will appear.
Step3
Touch on Agree and Continue.
Step4
You move to the other screen.
Provide your phone number and touch on next. A message will automatically be detected on your phone and will proceed further.
Step5
If you have ever created an account with the same number, WhatsApp will look for backups. If you don’t want the backups you can skip the step.
Step6
Provide your profile info like username for your account.
Step7
The account is created successfully.
If you have an Android phone and you want to create a new WhatsApp account, first, you need to download the app. Download the WhatsApp Messenger app on the Google Play store and install. This is rated 3+. For iOS devices, download the WhatsApp Messenger app on the Apple App Store. It requires iOS 9 and higher. This is rated 12+ for the following:
- Infrequent/mild horror/fear themes
- Infrequent/mild mature/suggestive themes
- Infrequent/mild profanity or crude humor
- Infrequent/mild medical/treatment information
Now, to create your new account, launch the WhatsApp Messenger app then tap “Agree and Continue” to accept the ToS or the Terms of Service and then tap “Continue”. Tap “Allow” when you are prompted with the following:
“Allow WhatsApp to access photos, media, and files on your device?”
“Allow WhatsApp to access your contacts?”
After this, enter your phone number then tap “OK”. Next, enter the verification code that is texted to you then tap “Next”. And that’s it. You are now signed up with WhatsApp.
