How To Make Animation
Nowadays I’m really into animation. Is there any software that I could use to make animation at home?
There are much software for making animations; even the video editor is also used to make some animations. But it all depends on what type of animation you are thinking about. Before moving into animation, it is better to make animated characters on paper because if you don’t know how to make animated characters you would not be able to create any type of animations except some stick characters. Even if you know how to draw it doesn’t mean you can start animating, before this you have to learn some fundamental real-life physics like hand and leg movement while running.
But to animate perfectly, you can’t use the mouse. That is where the graphics pad comes in. So before you do any of the animations, you have to come prepared.
