How To Make Your Own Website
I wanted to start my own business, for this I thought of making a website detailing all the things in this, even making the facility of booking things. Can anyone explain me on how to make my website?
The traditional way of making this is through coding. If you know how to code, then you can go for this. Even though you might know how to code, it is a time-consuming process and would slow the down process of your business. So I would not recommend going for this method.
If you want to make a website within 5min to 10min, then you should go for online website making site like WIX the most popular one out there.
Or else you can try word press. Most of the sites are constructed through this software. You get a lot of skins, interactive icons, a ready-made interface that you can customize. But at times it gets confusing to use this.
After making one, you have to buy a domain for your website. This makes the website your own, but for this, you have to pay a yearly commission.
SO it’s all up to you, you can research and come with the best decision.
