How To Manage Exchange 2007 Repair Mailbox In The System
I want to manage the exchange 2007 repair mailbox so that I could manage my data along with the temp files related to the server. How to fix this issue?
Microsoft exchange 2007 has ended its support to the servers in April 2017 and it won’t be applying for any further assistance. If you want to use exchange 2007 repair mailbox than you should follow these steps –
1.) There is a simple command to be put on, but before that, there are some requirements to be keep checked. Check the storage space which should be enough for the temporary repair of the database.
2.) Check whether you have proper instructions and permissions to access the folders to repair your mailbox.
3.) Make sure that you are using the account of a server delegate or you have one.
4.) Always make a copy of files you want to repair in case you don’t lose important ones.
To run and repair your mailbox, the command is
ESEUTIL /P databasefilename.edb
