I have been getting msvcr100.dll file missing error for some time now. I thought I could solve this simply by downloading this dll file. I cannot seem to understand how to do this. Can you help me with msvcr100 dll download?
How To Msvcr100 Dll Download Windows
Downloading dll files is relatively straightforward. First, you need to find a website that has the required dll file, in this case msvcr.dll file available for download. Then you need to find out the folder in which you have to place the dll file.
There are a lot of websites that allow you to download dll files but it is advised that you only download files from websites that you trust so as to avoid getting infected by viruses or malware. What you need to do is find out from where to download msvcr100 dll. A simple google search will do. Download the dll file and then place it in the correct folder.
