How To Notify My Local Network Ip Address Manually And Easily.
Hey, what is my local network ip address also notify the stepwise method to allocated them for the easy understanding. Thank you in advance.
Hey, the my local network ip address is used to track your address in form of the IP’s and it is connected to the LAN or Wan depending upon the usage of the person’s. The LAN has default IP number and also has private numbers too. Below shows the steps for the same:
• First click on start button
• Next go to run
• Now open the cmd and next click on OK
• In cmd manually enter ‘ipconfig’ and then press enter.
• Next the IP address will be listed
• Now close the cmd by entering exit
