How To Outlook 2010 Encrypt Email And Enable It For Every Outgoing Mail?
Hello everyone
I want to enable the Outlook 2010 encrypt email. I’m not so conscious about my PC but in the case of my emails and it’s different.
Hello everyone
Step1. On the top menu, click on the file tab and then go to options.
Step2. Click on the trust center.
Step3. Select the trust center option button which would be present in the Microsoft outlook trust center.
Step4. Select E-mail security tab present on the left side of the window.
In the Encrypted e-mail area, check the checkbox” Encrypt contents and attachments for outgoing messages” and check it.
Step5. You have done with all settings, now click on ok, and your outgoing mail will be encrypted now.
