How To Perform WhatsApp Create An Accountusing An Android Phone?
Hello experts,
I recently switched to android phone and want to connect on social media. I was curious to know that what is the procedure to Whats App create an account on android phone?
Answered By 0 points N/A #304863
Creating a WhatsApp account is very simple. You can create account on WhatsApp just by following these steps:-
Step1. Very first step is to install WhatsApp application on phone. Either you can download it from play store or you can also use ShareIt or other app to get it from somebody else’s phone.
Step2. When you will successfully install WhatsApp on your phone and touch it a dialog screen will appear.
Step3. Touch on Agree and Continue.
Step4.  You move to the other screen.
Provide your phone number and touch on next. A message will automatically be detected on your phone and will precede further.
Step5. If you have ever created an account with the same number WhatsApp will look for backups. If you don’t want you can skip this step.
Step6. Provide your profile info like username for your account.
Step6. Your account is successfully created.
