I have installed both the version of Photoshop 32 and 64 bits. When I tried to run this version, then I get a photoshop configuration error one. And also tells me to uninstall and again reinstall photoshop. But when I again reinstall, it gives me the same error again?
How To Photoshop Configuration Error One Fix.
For solving this type of issue.
We just need to do that,
Install Photoshop of any drive in which you want to install.
Copy the whole contents of “C:\Programms files(x86)\common files from your normal window drive to the same location in which we want to install it.
That’s because you installed both versions on your computer. You should install only one version. If you are using 32-bit Microsoft Windows, you are limited only to the 32-bit version of Adobe Photoshop. But if you are using 64-bit Microsoft Windows, you can install either 32-bit or 64-bit Adobe Photoshop.
Though you can install either of the two, you should not install both versions on your computer because it will create conflict between the programs particularly with the resources and permissions. If you have 64-bit Microsoft Windows, install only one version either the 32-bit or the 64-bit.
To maximize the capacity of your computer because you are using a 64-bit operating system, installing the 64-bit Adobe Photoshop would be the best choice. So, to fix your problem, uninstall the 32-bit Photoshop. Download Revo Uninstaller Freeware 2.0.0. Follow the instructions to download and unpack and then install it. Once installed, launch Revo Uninstaller, select the 32-bit Adobe Photoshop from the list, and then click “Uninstall”.
Follow the succeeding instructions. When it is finished, restart your computer then download and install CCleaner. Once installed, start CCleaner and clean your system. See if this works. If you want to register CCleaner, download CCleaner Registration Codes and follow the instructions.
