I have deleted some of my mails from the Outlook account. Nevertheless, now I need them now. How can I recover or restore them? If so then please tell me how to recover deleted items from Outlook 2007.
How To Recover Deleted Items From Outlook 2007 Easily?
This is possible to recover deleted items, even if they are permanently deleted. Go into the tools menu and select recover deleted items.
To use this command you must be using an Exchange account. If you don’t see this command then you need to contact the administrator. These simple steps can be followed in recovering the items you deleted from the Outlook 2007 mailbox.
If you are using Microsoft Office Outlook as your email client and you delete items or messages in your inbox or other folders, it doesn’t go away immediately. The item or message you deleted will go straight to the “Deleted Items” folder or “Trash” folder whichever is available on your account. Unless you emptied the folder, you can still recover your deleted items.
To recover or restore any item or message you accidentally deleted, in Microsoft Office Outlook, click or select the “Deleted Items” folder or “Trash” folder on the left pane then locate the message you want to recover. Once you locate the message, right-click it then select “Move” and then “Other Folder” or select a folder where to move the item.
On the other hand, if you can’t locate the item or message in the folder, the next place to look is the “Recoverable Items” folder. It is a hidden folder and this is where items are moved when you delete an item in the “Deleted Items” folder or you emptied the “Deleted Items” folder. In Microsoft Office Outlook, go to “Home” tab then select “Recover Deleted Items From Server”.
If you don’t see this then that means your account doesn’t support recovering an item that is no longer in the “Deleted Items” folder. Locate the item you wish to recover and select it. Select “Restore Selected Items” on the bottom left of the dialog then click “OK”. When you are finished, you can find the recovered item in the “Deleted Items” folder.
