How To Rectify This 3dsprofileserver Exe Has Stopped Working Inside PC?
Hello, Everyone! I got this 3dsprofileserver exe has stopped working error inside my PC. Can you guys help me correct this issue?
A) To fix this 3dsprofileserver exe has stopped working error, you will need to follow these steps:-
1. Close the error message and then open up your Task Manager inside your PC.
2. Now, kill all processes that are related to the program that have crashed and are showing that error.
3. Now, restart the program and system.
By killing the programs related to it inside the task manager, it sometimes solves the issue as it could be a time error. So it might solve your issues.
B) To fix this 3dsprofileserver exe has stopped working error, you have to run the program in compatibility mode by following these steps:-
1. You have to go to the install location of the crashed program.
2. Then, find the .exe file and, Right-click on it, and select the Properties option from the menu.
3. Now, go to the Compatibility tab and Run this program in compatibility mode.
4. Select another Windows version from the menu and press the OK button.
It might run smoothly and will not crash.
