How To Remove Epson Wf 3640 Error 0x97
I have owned the epson printer for years now. Recently, it has started throwing epson wf 3640 error 0x97 in between printing. The problem is that the printer refuses to print until the error is removed. I cannot access the printer when this error comes up. How to remove this error?
Answered By 0 points N/A #321739
The error you are describing is very common among users who have used Epson printers for a long time. No hardware ever comes a hundred percent problem free.
The epson wf 3640 error 0x97 error code indicates an internal hardware problem in the printer. This basically happens over time as the printer becomes older, it is bound to build up some problems. The way to remove this error is basically to find the problem and fix the hardware. You need to download the error 0x97 fix patch from the Epson website and scan the printer to find what the problem is. You may need to call Epson service for the same.
