I noticed a lot of junk on my computer. I especially noticed all the temp files. I also read on the internet that temp files can take up a lot of space and deleting them from time to time is advised. How to remove junk files on Windows 7?
How To Remove Junk Files On Windows 7
Various programs that are installed on your computer fill the temp folder. Deleting the temp folder is not possible but emptying the temp folder is very much possible. Follow the steps below to empty your temp folder.
Press Windows+R to open the Run Dialogue. Type %temp% and press Enter. This will open the temp folder. Now, like you delete any other file in any other folder, you can empty the temp folder. To make short work of this, press CTRL+A to select all the files and press delete. This will delete all the files and empty the temp folder.
