How To Remove Mscoree Dll Missing Error
I was trying to install GTA V when I got the error, “there was a problem starting mscoree dll. The module cannot be found.” I do not know what to do with this error. Is there a way I can remove this on my own?
Answered By 190 points N/A #322923
Mscoree.dll is a DLL file that is associated with the Microsoft .NET framework. It is a Microsoft Runtime Execution Engine, and therefore contains important scripts that are required to run programs on Windows.
The error message states that the mscoree.dll file is missing from your computer. So, to remove this error, all you need to do is find this DLL file on the internet and download it. Then, place it in the required folder. DLL files are placed in the Systems folder. However, games sometimes require that DLL files be installed in the installation directory.
