My brother and I are trying to install new Windows on our computer because the old one got corrupted. During the installation, we keep getting the error windows error code 0x8007025d. We cannot figure out how to remove this error. Can you help with this?
How To Remove The Windows Error Code 0x8007025d
So when you get the error Windows error code 0x8007025d while installing Windows 10 or even Windows 8, this usually means that you do not have the product activation key or you have misplaced it. This is common when installing Windows from a flash drive or a USB drive.
The first course of action is to run automatic troubleshooting. If this does not work, try changing your boot option. Try changing it to CD-ROM instead of USB. If even this doesn’t work, try to install Windows after disabling your third-party antivirus. This solves several problems. Lastly, you can delete all your temp files and then start the installation.
