I want to install a particular update from Microsoft Updates. When I try to do so, Windows throws an error code 0x8007371b and says it is unable to download the said update. I think I require this update for my computer to work properly. How should I move forward despite this error?
How To Remove Windows Update Error Code 0x8007371b
The error code 0x8007371b is generally seen while downloading or installing Windows Updates. This error code indicates that the update you are trying to install is either missing or the update is somehow damaged.
To solve this issue, you can do a couple of things. First, turn on the Windows Update troubleshooting utility. This utility will run a diagnosis and will guide you through the actions that are required. In case the troubleshooting does not yield anything, you can try and run the DISM tool. If even this doesn’t work, try and reset your Windows Update settings and try and download the update after that.
