I have bought a new laptop and it worked fine for the first few days. Now I am starting to get a weird error repair 0x80030001. It is a new laptop and I am scared. Was I scammed and got a broken laptop or is there a fix for this problem?
How To Repair 0x80030001 Error Code Windows
No, your computer is not broken rather, your operating system is. If you are getting this error, it means that there is something broken in your system operations. This error can harm your computer in the long run.
There are solutions to this problem. Errors of this kind are generally fixed by manually editing the operating system’s registry. This process is dangerous because when done incorrectly, it can lock you out of the system forever. Therefore, I would suggest that if you are not confident with your technical abilities you call tech support. They will be able to handle this with care.
