How To Resolve 0x80030309 Error?
Hello, I am getting an error 0x80030309 while I was trying to copy something into the DVD; please help me with the steps to fix it. Thank you.
Hello. The error 0x80030309 occurs while copying content into or from DVDs; it displays an error message “error: 0x80030309 copy protection error- the read failed because the sector is encrypted.” The reason for this error is if you are trying to copy a Content Scramble System- encrypted DVD or UOP or APS DVDs data.
Follow this method to fix the error.
• Open the browser, search for the best DVD rippers, download a good DVD ripper(we suggest WinX DVD Ripper). Download and install it on your PC.
Note: using a DVD ripper might reduce the quality of the video.
• Load the disc into your system, now launch the DVD ripper program and in the top left corner of the screen, click on the disc icon; WinX will make a quick scan on it.
• Next, choose the output format.
• At the bottom right corner of the screen, Click on the run button.
This method will fix this error, and you can also repair any other errors related to DVDs using this tool. Thank you.
