How To Resolve 0x80073cf9 Microsoft Store Error?
I am facing a problem while downloading apps from the Microsoft Store. The error code is – 0x80073cf9? How can I resolve the issue?
Corrupted Microsoft Store components can cause 0x80073cf9 error. Here are the methods to fix it –
Method 1
a. Right-click on the start menu.
b. Open Windows PowerShell (Admin).
c. Type Get-AppxPackage -AllUsers| Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\AppXManifest.xml”} and press enter.
d. Try to download the app.
Method 2
a. Open This PC.
b. Go to the C drive.
c. Open the Windows folder.
d. Create a New folder here.
e. Name it as AppReadiness.
f. The store should work now.
Notifications
