How To Resolve 0x800f0922 Error While Updating Windows 10?
I am facing a 0x800f0922 error while I am trying to update my Windows 10 version. I am not a tech-savvy person, and I cannot solve the problem. Please help me to solve the error.
There are mainly two reasons that cause the 0x800f0922 error –
a. Insufficient memory space.
b. VPN connection.
Solution –
Method 1
a. Open This PC.
b. Check the drive with the Windows Symbol on it.
c. Make sure you have at least 10 GB free space on this drive. It is always preferred to keep 32 GB of free space.
d. You should be able to proceed with the update.
Method 2
a. Disconnect the internet from the PC.
b. Disable your VPN software.
c. Reconnect to the internet.
d. Perform the Update successfully.
e. Restart the VPN if you need it.
