How To Resolve Error Code 12
Please, help me to remove error code 12. I am a Windows 8 user. How can I avoid this bug from my Computer? Reply fast.
If you are facing this bug then check that no two devices are connected at the same time to input-output port or same DMA channels which stand for Direct Memory Access. This bug is related to memory.
BIOS is also the reason for this type of issue if it does not allocate resources to the system. To avoid this error then go to Device Manager and then go to properties and start troubleshooting Window. If it does not work then restore your computer. Make sure to take backup of your data before restoring your machine.
If you installed a version of Windows SDK on your computer, check that it is compatible with your operating system. Try to uninstall and reinstall the software. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your Windows SDK among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then install your Windows SDK back. See if this works. Also, if you are currently developing an app with the Windows SDK, check the functions and instructions in your code.
The error says “The parameter is incorrect” which means the problem is with the code in the program you are developing. Check the values and make sure all variables, instructions, commands, functions, and other commands are valid.
