Hi Iam not an IT person and Idon’t belong from an ITdomain. Iam having this Hard Drive error which is MSGErrorcode 2000-0146 it makes a beeping buzzing sound. Please help me resolve this problem. Thanks in advance.
How To Resolve Msg Error Code 2000-0146a Hard Drive Error.
When this error occur it is mostly because the hard drive has failed or its corrupted. So in order to confirm that we need to go through a process. First, you need to put in the windows installation disk in your device drive. Press any key when the installation, after that choose the language, the time etc then click next. After that select the Repair option from the list and then choose the appropriate OS you want to repair and then select Next. After this click on Command Prompt in System Recovery Options window. Now the Command Prompt will open up and type in “chkdsk/r” and press the Enter Key. After all, this if there are error your Hard Disk is faulty.
