JOSE Adams
10 points
Posted on - 02/23/2017
I am using SAP services on my computer. I have installed Windows 7 operating system. I keep getting the SAP Logon balancing error 88 while using the service. I tried many solutions, but none of them work. How to resolve this error?
How To Resolve SAP Logon Balancing Error 88 In Windows?
There are the following two solutions to your problem.
1. Find a file called saplogon.ini in your directory. This file must be situated in the same folder where you have installed the SAP service. Make sure there is the right saplogon.ini file present in this directory. You may replace this file with the right .ini file from your computer. Delete the old file. Your problem should be rectified.
2. You can also try to do as follows. Reinstall or update the SAP drivers from Control Panel. You also need to make sure that the sapmsSID is correct along with the IP address and hostname.
