How To Resolve The 0x80042109 Error?
Hello experts, I am getting an error 0x80042109 while sending an email or receiving an email; it displays an error message saying Outlook is unable to connect to your server. Please help me to fix this error. Thank you.
Answered By 0 points N/A #340977
Hello, The cause of the error 0x80042109 might be improperly assigned SMTP server protocols or due to several third party applications. Follow the below-mentioned methods to resolve the error.
Method 1:
Outgoing port.
• Go to MS Outlook.
• Click on tools, then go to the account settings.
• Now, right-click on the email address you are using.
• Click on more settings, go to advanced.
• Change the outgoing SMTP server port to 587 and choose TLS encryption.
• Click on ok and follow the prompts.
Method 2:
Firewall settings
• Search for Firewall and click on it.
• On to the left-hand side, go to “Allow an app or feature through windows firewall.”
• Select change settings.
• Now enable Outlook.exe and msimn.exe for public and private networks.
• Apply the changes made and restart the PC.
