How To Resolve The 0x80070002 0x1000a Error?
Hi there, I’m getting the 0x80070002 0x1000a error while installing Windows 10 on my PC. Please help me with the methods to fix it. Thank you.
Hello. Getting the 0x80070002 0x1000a error while installing Windows 10 on your PC. Follow the below methods to troubleshoot the error.
Method 1:
Windows Update Troubleshooter.
• In the Windows search box, enter Troubleshoot and click on troubleshooting.
• Select Windows Update and click on the run troubleshooter button.
• In the next prompt, choose the error which you want to fix this, or if you wish to skip it, select to ignore it.
Method 2:
Date and Time settings.
• In the Windows search box, enter time & date settings and hit enter.
• Next, check if the settings of set time & time zone automatically are enabled, if not enable them.
• Restart your system and try installing or updating your Windows version.
