How To Resolve The 0x80070002 Error_file_not_found Error?
Hello, experts. I am getting the 0x80070002 error_file_not_found error while trying to open a file. Please help me out with the solution. Thank you.
![](https://www.techyv.com/sites/default/users/Images-Folder/How-to-resolve-the-0x80070002-error_file_not_found-error.jpg)
Hello. Getting the 0x80070002 error_file_not_found error. This error means that the required file is missing. Follow the below steps to fix this error.
Step 1:
• Search for the command prompt and open it as an administrator.
• Next, type the following statements and hit enter after each command.
“SC config wuauserv start= manual”
“SC config bits start= delayed-auto”
“SC config cryptsvc start= auto”
“SC config trustedinstaller start= auto”
• The above commands will boot the computer and make sure that all the services are available in your PC.
Step 2:
• Next, type the following statements and hit enter.
“chkdsk C:/f/ r / x”
This step might take some time, so wait till it completes.
